on 13-12-2023 01:54 AM
Hi, I have a EE smart hub Plus I was wondering will it not matter if I went for a EE smart WiFi or EE smart wifi Plus because I need most of my WiFi to boost around my home
13-12-2023 02:14 PM - edited 13-12-2023 02:19 PM
Is there such a thing as "Smart WiFi Plus"? Accompying the Smart Hub Plus is the white extender called just "Smart WiFi" (Model No. SW30A).
on 13-12-2023 07:41 PM
@Matty2003 If you already have a Smart Hub Plus as part of your plan and want to go for the EE Smart wifi add on, you'll be provided with Smart Wifi Plus which has wifi 6.
Cheers
Neil
