Wifi on new hub pro
Mally19
Have been using the new wifi 7 router and wifi hub pro now for a month or so, not sure if I'm doing something wrong, followed the procedure in the box, router works fine and hits speeds as my contract.
My issue is the wifi , barely scraping 50mbps on my tv , and less than 20mbps on my laptop using wifi, tv is less than 2 metres away with only a door inbetween, distances from hub to wifi pro are a ceiling and wall away, surely this should be faster!
Came from a bt hub and disc which had stable faster speeds on older tech.
Also the wifi hybrid connect, never stays connected.
Bit annoyed as work from home most days and need a stable connection,  is there anything I can try before I reign hell down on some poor employee of EE.
20 REPLIES 20
Profile closed
Not applicable
@Reign_in_Beard
Ha. I have my own card for those kind of purchases. Just not for that amount, as ultimately it’s pd from our joint a/c.
Every man should have a slush fund. Listening to a podcast on Trafalgar the other day, learned the origins of the phrase.
