Wifi Intermittantly Dropping Devices
Miller878
Hi all,
can somebody with knowleddge please have a look at the logs attached and advised if they see anything strange?
My laptop keeps disconnecting all the time from the home broadband. It may be a signal strength issue as my DB is around -70 to -67 where I sit. Want to rule out anything wrong with the broadband or router first prior to purchasing a wifi repeater.
thanks Tom
Miller878
if anyone knows how i can share the log files on here that will be great....
Use the Camera icon above your text to upload an image file to here.
