WiFi problems
Suzberlin37
Help, I have a problem that is driving me crazy! Had persistent problems with my wifi dropping in and out. Happens at all times of the day accross all devices. Had 3 EE engineers and 3 Openreach out to look. Last one thought the cable might be damaged coming into the house and this was changed. This seems to have sped up the WiFi but still drops in and out. Seems to effect mainly those things that would require an ipv4 address such as ring, and internet searching and some apps. It seems that the router can't assign and ipv4 address on occasions and that's what causes it to drop out and then as it keeps scanning eventually is able to assign. Is there anyone else that has had this problem and knows what to do? I have also had multiple routers supples by EE to try but I'm kinda at the end of my tether with it all. Thanks
21 REPLIES 21
They might not be old but they are WiFi-weak. Ring doorbells are WiFi4 (802.11 b/g/n @ 2.4 GHz) . They certainly won't like WPA3.
@XRaySpeX They are not all, Ring do have a 5Ghz wifi 5/6 version as well. Agreed WPA3-Personal would not even function as chipset not up there yet i think but it may be on a wifi 6 device.
