21-09-2026 01:13 PM
I’m having issues using WiFi optimiser while online multiplayer .Download and upload speeds drop dramatically and cause more issues than solves.
21-09-2026 03:41 PM
Thanks for the response. I forgot to mention that I’m fully wired when gaming I know how to use ping optimiser geo filter and adding your console and game to the settings . But no matter what I do no improvements.
21-09-2026 02:04 PM
@Pete5555 That is one for you to take up with EE CS, optimiser addon service working or not? The link for it's explanation is below.
Boost Your Connection with WiFi Optimiser | Broadband Help | EE
21-09-2026 03:41 PM
21-09-2026 03:46 PM - edited 21-09-2026 04:00 PM
@Pete5555 Have you looked at doing your own then, after all you have an ISP supplied hub and if it's not working out plenty more different Routers are available with better options for QOS. You may find the utility below useful for checking to run on your network.
