WiFi enhancer
Hannahlou33
Skilled Contributor
Skilled Contributor
Has anyone had geo filter working lately use to work perfectly now can never get it to work shows servers but doesn't connect to them then they disappear and it always says I've lost connection to smart hub pro any ideas tryed everything
15 REPLIES 15
Hannahlou33
Skilled Contributor
Skilled Contributor
Geo filter only working with wireless connection but not hard wired. Having my Xbox series x wired the router changing recognizing it as console
Leanne_T
Hi there @Hannahlou33
Thanks for coming back to us.
Following your last update, did you hear back from the team with an update?
Thanks.
Hannahlou33
Skilled Contributor
Skilled Contributor
No never heard anything but I can get geo filter working but only wireless the router not recognising the Xbox as console when hard wired must just be a problem with smart hub pro as it work with smart hub plus
Leanne_T
I see, thanks @Hannahlou33
I would suggest getting back in touch to see if the team have an update for you.
Hannahlou33
Skilled Contributor
Skilled Contributor
Ok will do
Leanne_T
Thanks @Hannahlou33
Let us know how you get on 🙂
