09-10-2025 08:50 PM
Hi everyone,
I was upgraded to the EE Smart Hub Pro and WiFi Pro units this week on my 1.6Gbps service. Very impressed so far and definitely notice the difference over the Smart Hub Plus. It's also so far resolved a disconnection issue I was seeing on the plus device.
As part of the set up I enabled WiFi Enhancer for work and gaming. However when I try to turn them off or turn on stream mode it loads the DumaOS screen and then displays the message: "Dashboard not implemented for this unit".
I've tried power cycling the router and still getting the message. I can see what is enabled in the app, it's when I try and click in to change it. Ping optimiser and geo fencing seem to load.
Any ideas with this specific error? I don't want to reset the router given i got it up and running etc yesterday, but might have to if it's the only way to turn off the enhancer.
MikeAlanR
11-10-2025 09:42 PM
Hi @bobpullen
It's the app on my Z fold 7. As far as I'm aware you can't enable WiFi Enhancer though the router settings only via the app.
MikeAlanR
22-10-2025 12:11 PM
@MikeAlanR - ah, I wonder if that's also being seen as a tablet device given the extended screen viewport. Did you have the app open whilst the device was unfolded? I wonder if it's any different if you use just the front screen with it closed (if that's possible?)
Another suggestion would be to try temporarily changing your default browser. e.g. if it's currently the Samsung Browser, then try installing Chrome and setting that as default before giving it another bash.
