Wi-Fi printer
Jersey3
I have just switched broadband from BT to EE, smart hub plus installed no problems., working fine. Cannot get Canon TS3550 WI-FI printer to work no being recognised on my IPAD.
6 REPLIES 6
Jersey3
@Jersey3 : Have you connected the printer to your router, either by WPS or by supplying route's SSID & pwd to it? Even before you touch the iPad.
How do I add SSID and password, never had to do this when set up this WI-FI printer to my BT router, just followed the canon app when I unboxed the printer etc etc.
Mustrum
@Jersey3   you need to start again with the Cannon app and connect the printer to the new EE network, like you did when you set it up with the BT Router.
Manual below to remind you.
https://ij.manual.canon/ij/webmanual/Manual/All/TS3500%20series/EN/NTR/faq_003.html
Somehow managed to recognise the printer on the network, printed document OK when switching off WIFI, when print job finished enabled WI-FI OK.
Mustrum
@Jersey3  glad you have it sorted, happy i was able to help.
