20-10-2024 07:55 PM
After going INSANE on what is causing connectivity issues on my network I (think) i have found the issue. Phillips HUE box within a few meters of the router (hard wired in) causes so much interference other devices drop off. Posting this hoping it may help someone else! Fingers crossed this is it…. It’s still wired in just moved a lot further away…
(smart hub pro box and also same issue prior with smart hub plus)
21-10-2024 11:32 AM
Hey there @Gonz2, thanks for taking the time to share this!
I can see you've posted a few times in the past about issues with your connection, so I'm really glad you managed to find the source of the interference.
Fingers crossed this can help anyone facing similar issues in the future too 🤞
Peter
