What to replace old BT wholehome disc with after switch to EE?
John2585
I used to use BT and had a Homehub 3 and black whole home/Halo disc to provide coverage around my house and into my garden room. I switched to EE and now have a black Smart Hub Plus which is incompatible with the BT whole home disc.
What wifi extender/access point devices are compatible with the EE Smart Hub Plus (Black)? I know the EE wifi extender is compatible but would rather pay for a device outright rather than rent one monthly.
Any advice appreciated.
Ewan15
Expert Contributor
Expert Contributor
@John2585 Welcome to the forum. Unused EE wifi extenders are available from a certain well known Auction site.
I would think about your options if you want to go down this route as you could purchase the Pro Router and Pro Extender instead
Maestro
Maestro
@John2585 Take a look at the, has been reported to been on the system with users before. The Asus RP-AX58 also worked before EE stuffed up the latest FW to the plus router. Buy from somewhere that you can return if it does not play nice.
TP-Link RE700X WiFi 6 AX3000Mbps
The white "High St." BT Whole Home discs should be compatible.
@XRaySpeX Glad to see you are now putting up the "should" be but with all the people posting issue's that creep in aver time and finding that they are a problem, in theory yes but too many postings with issues.
@JimM11 : Well, if you buy them from a shop that honour the statutory cooling-off period, you can soon find out.
Really? I don't see many Whole Home issues but then there are not many reported uses of them with EE routers.
