What hub can I connect to the Smart Hub Plus?
erossini
Hi everybody,
I have just received the new Smart Hub Plus. This hub has only 4 ethernet ports but at home, I have more devices to connect using ethernet (not only the WiFi). I would like advice about what hub I can buy to "extend" the ethernet capacity.
I saw this device on Amazon https://amzn.to/3ZiRdhZ, and I think it is what I'm looking for.
Thank you in advance!
You should be able to use any unmanaged switch.
jcapricorne
An ethernet splitter (switch) plugs into the one of sockets on hub.  You can even plug in a splitter to a port on a splitter.  The number of ports on a splitter varies, I have one with 12, another with 4.
