Wan link speed 1000 Mbps
JakeyB2
I'm considering upgrading to the 1.6gbs package, as I already have the smart hub pro with 2.5gbps ports.
However I noticed in my router settings, the Wan link speed is at 1000 Mbps.
Is this because I'm not currently on the 1.6gbps package, or because the ethernet cable they provide doesn't support faster than that?
1 ACCEPTED SOLUTION
Mustrum
@JakeyB2  if you order the 1.6Gb service, your ONT will be changed to a 2.5Gb one, your link speed will therefore increase.
Mustrum
Ah ok great thanks, that makes sense!
