on 20-02-2022 10:01 PM
Hi all
I've searched the forum but can't find what I need.
In order to connect my printer it wants me to press WPS on my router. There doesn't seem to be a button for this either on the machine itself or in the router settings via http://192.168.1.1
Please can someone help?
on 20-02-2022 10:25 PM
There's no WPS on the 4GEE WiFi Mini. You'll need to connect your devices manually using the network SSID & pwd printed on the label on the back of the battery cover & on the KeepMe card.
on 21-02-2022 09:16 AM
That doesn't seem to be an option on my printer.
on 21-02-2022 09:34 AM
Can't you connect by USB or even Ethernet and set it up that way?
on 21-04-2022 12:15 PM
I have the same problem…there’s no wpd button on the mini hub and my printer doesn’t have a screen to enter any passwords. When I had Sky I simply pressed the Wi-Fi button on the printer (Epson et-2500) and then the wpd button on my router and it recognised the printer and automatically connected it. Any ideas?
on 21-04-2022 12:27 PM
@Bluesboy you could connect the printer to your laptop/pc by usb cable, then follow the instructions in the manual to change to Wi-Fi.
on 21-04-2022 03:06 PM
Thanks I’ll give it a try.
