WIFI password
Swifty6
I am using a USB dongle with a Sim card in to get broadband. Other than using it in a laptop, I would like to use it on several devices.
Am I right in thinking in a list of WIFI, it comes up as 4GEE Router - 552W? If so, it is asking for a password which I don't have.
Does anyone know where I can find this?
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the admin password found under the battery cover. Then, if the WiFi password is not also found under the battery cover, on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
