on 25-10-2024 10:15 AM
Just had EE installed with WIFI 7, hoever no matter what i do even tried rebooting the sytem and leaving it on over night to see it would self resolve i am still getting flashing orange lights on the wifi 7 booster, is there anything else i can do or is it a faulty booster.
on 25-10-2024 05:02 PM
Hi, have you tried pressing the WPS button on the Booster, and then the WPS button on the Wifi 7 Router?
Alternatively, move the Booster closer to the Router and connect with Ethernet cable until the lights go Aqua. Then you can unplug and re-position.
on 25-10-2024 05:04 PM
I trid the first but not the second will try tonight.
on 25-10-2024 09:07 PM
@JohnRI Positional wise, were in relation to the router is your booster, rough distance, through number of walls and floor boards etc, mesh does take sometime to tune itself one to the other, and moving a few feet closer can have a dramatic effect if just on the verge of the crossover, plus do you have any other wireless devices transmitting at the same time?
on 26-10-2024 01:44 AM
had absolutely same trouble...
I connected it vias UTP cable to router, and connect it that way... seems, it's updated WiFi extender FW and after hard reset, subsequent connection wirelessly worked well...
on 26-11-2024 09:03 PM
Same here. Everyone screaming at home.
on 26-11-2024 09:11 PM
@Sam_Ashiq It's a process that you have NO influence over, if you cannot wait then have everyone gather round and work of the router wireless signal as best they can.
