Very unstable broadband
Hamlet
Hi, our broadband has been very unstable since yesterday evening, even before the storm came in.
The hub seems to connect well and doesn't seem to disconnect from the network, but it keeps cutting out connections on various devices including mobile phones, laptops and iPads.
Does anyone have an idea about what's the cause?
