Using Deco M4 as router
Vinotinto
I've just switched from BT full fibre to EE full fibre 900mb
I managed to replace my Bt hub with a Deco M4 in router mode by following guidance from a forum...
Does anyone know the details shown in the screenshot for EE?
You'll need your EE BB Username which you'll get from the supplied EE router before you discard it. If your Username looks like PRODUCTIONHQNUN123456@fs, your Password will look like HQNPASS123456. Simply replace the numbers in the password, with the ones found in your username.
With a bit of luck you might even find that the BT creds given in your screenshot might work with EE BB.
