on 18-09-2025 07:15 PM
It's all in the title. Can some technical whizz break down the pros and cons?
Essentially, is it a good idea to upgrade from Smart Hub2 to Smart Hub Pro wifi 7 when I only have the normal 67 fibre package and not the full fibre?
Have people done this, and does it noticably improve 1) Speed 2) Latency 3) Range 4) stability ?
on 18-09-2025 07:20 PM
The Smart Hub Pro WiFi 7 does not have an ADSL/Gfast modem and would require an external modem for FTTC.
on 18-09-2025 07:48 PM
@Chris_Gee The speed is governed by your contracted tariff speed. Ie 67meg you’ll not get faster because of having a wifi 7 router it’s still 67 meg.
on 18-09-2025 09:12 PM
It would be overkill even if it had a DSL modem or you'd supply 1.
