20-10-2026 11:29 PM
I have tried EVERYTHING I think I’m gonna go back to fibre 150. Works faster and better!!! Pmsl SERIOUSLY
20-10-2026 11:51 PM - edited 20-10-2026 11:51 PM
@Nh3GoD : Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working? What colours are the light sequence when it happens?
BB issues are rarely widespread but specific to your own line.
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
20-10-2026 11:55 PM
@Nh3GoD Did anything else change at the same time, plus are you getting expected speed wise, if the app is working and you use it the speed test function should show both entries and a pass fail for your min.
