Unacceptable delays by EE to install ONT - Help/advice ?
MultiDoc
Valued Contributor
Valued Contributor
As a last resort I am posting this in case anyone can offer any help or advice.
I first placed the order for Full Fibre 1.6Gbps back in early December, the 13th to be exact. Was given that day a date for hardware (router etc) to arrive on the 6th of January and date of service to go live on 9th of January. I thought it's not ideal almost a month but not too bad.
I received the hardware in fact earlier than the 6th, a couple days or so earlier. 9th January came and past but nothing happened. In the end Openreach came, did a quick survey and a few days later came and did the digging from the walking path to the outside wall and install the optical fibre cable, this was done a couple of weeks ago. Was told that all was left was for the engineer to come and do the final step and install the ONT and the service to go live.
To my (unpleasant) surprise, later the same day (or the next, not sure) I received an SMS and the app also was updated that my order was expected to go live the 6th of February... A day or two later I received another "update" that the installation was "confirmed" for the 12th of March! And also an SMS thanking me for changing the appointment sucesfully.
I do appreciate this must have been a typical generic SMS, but the waiting for 2 months just for the ONT installation after all the outside work was done seemed a bit too much for no obvious reason. Especially when the outside work was in fact finished before the original projected date.
So i called EE and explained that everything was ready and waiting and the appointment I was given 2 months later can and should be expedited to as soon as possible. After several phone calls, telling me Openreac h won't be able to have an engineer available for the installation until another 4 days and I should call again later, which I did last Friday, only to be told again no expedited available appointments to be had. I was asked to call again to day which I promtly did again. Mind you all these phone calls have been at least half an hour each, with lots of waiting on hold for EE to speak to Openreach...
So earlier today, yet another phone call later, I was told again that the 13th of March is the earliest available...
Is this really the experience other members/customers have ? 3 months from ordering to getting the service ? And two months waiting for ONT installation after all outside work has finished ?
Is there any way I can do something about this to get the service sooner ? Any other way to contact etc ?
I'd appreciate any help.
P.S: The icing on the cake is that BT (current ISP) although it has been a pain over the years with slow speeds all rounbd, it has been rock solid but started having random drop outs and disconnect and ridicoulously slow speeds since the outside work was done. And I do work from home 2 days a week plus weekends too, which is currently at best problematic if at all possible at times.
26 REPLIES 26
MultiDoc
Valued Contributor
Valued Contributor
Spent another 40 minutes on the phone today in hoping that this 2 month extra (plus 1 month for the original appointment) could be shortened and an expedited appointment could be had, but alas...
I will raise a complaint (again) and at the very minimum I'd expect EE to credit my account once it goes live with these 2 months (hopefully not more)
@MultiDoc Think that 60 day's is the absolute max for compensation. Heads up if you want to check that out.
Automatic Compensation | Broadband Help
What's the maximum amount of compensation I can get?
The maximum amount of compensation for a total loss of service fault or delayed activation is 60 days. If we can't fix your service after 30 days, you have the right to leave us with no termination charges.
MultiDoc
Valued Contributor
Valued Contributor
Thanks, I've read that and I just filed a complaint via the website form. It feels like talking and dealing with a wall to be honest. I really can't see how 3 months from order to getting the service (especially after being given a date for less than 4 weeks from ordering) seems for everyone involved "normal" and reasonable or whatever.
Liam611
I was meant to get a engineer out yesterday to install my hub and all that but because of the storm they never came no text no phone call I just want to know when they’ll come out
@Liam611 You will have to call EE CS to find that information if they have not already contacted you with a re-schedule of the appointment, the forum does not know.
MultiDoc
Valued Contributor
Valued Contributor
Hello again (after quite some time). Update:
After several (unsuccesful every time) attaempts to get the engineer appointment changed to an earlier one; and by the way each time I was given a different fake excuse, the final installation happened a couple of weeks ago. Thankfully at least the engineer that installed the ONT and did the drilling etc was very nice and took my advise and followed my instructions and advise. He did a very good job indeed and tidy.
I still have a complaint open (or at least I hope) regarding compensation for the 3 month long delay from order to getting the service up and running. I was told it might take up to a month and eventually should be credited towards my EE account.
As for the actual fibre service itself, it's working great so far. Only used the EE hardware on the first day when the engineed was here to check everything was working etc. But since the first day after the line was up I have been using my Asus ZenWifi BQ16 and has been running great, stable and fast as expected with lots of config options.
Lastly, to give you an idea, my order was plaved on 13th of December with an expected live date on 9th January but instead happened on 12th of March. At the same time my next door neighbor (literaly next door) had everything done from date of order to day of service being up within 3 weeks...)
Not happy at all to say the least with the experience but fingers crossed the actual product will be as good as it has been so far in the first couple of weeks.
