20-02-2024 08:43 PM
Hi. My Toshiba TV no longer connect to router. It does however connect to my mobile phone. It recognises my EE WiFi but does not accept password?
Any suggestions gratefully recipes.
20-02-2024 09:10 PM
If it was working at one point, try rebooting your router. This happened to me as well a couple of times where it keeps saying password is incorrect on wifi even though it’s correct. Rebooted router and it worked fine after, not sure if you’re issue is the same but worth a try if you haven’t already
02-03-2024 03:00 PM
Your TV is probably on an older type of security protocol than your router is set to , you might have to lower the security protocol on your router to WPA2
