on 17-11-2025 07:44 PM
Hi, ive got an old toshiba laptop which ive been trying to get working recently. My only question is, is there any way to revert the EE Super Hub Plus from Wifi 6 to a more compatible standard for older devices??? Before you say it, yes I've tried the "Compatible WiFi" option ( which is completely useless as it's still WiFi 6 based, so the laptop doesnt recognise it ). Thanks
Solved! Go to Solution.
on 17-11-2025 07:50 PM
Set up "Compatible WiFi" with the 2.4 GHz band only.
