11-09-2025 02:20 PM
Hi
My switch over date is tomorrow.
I have had sent me 2 Wifi 7 routers (the smart hub pro and the smart wifi pro)
Just trying to get some feedback on here from anyone on a similar setup.
How easy was the switch-over process? Any tips or anything in particular I need to know before doing so? How are you finding EE broadband in general?
With regards to the router(s) is there a separate router app that I use for configuration, or will that become available in the My EE app once its live? Or is it better to log into the router via a browser to configure it?
Paul
11-09-2025 04:30 PM
IMHO it is better to log into the router via a browser to configure it but there is some config you can do in the EE app particularly access & parental controls.
The Smart WiFi Pro is not a router but an extender.
