29-06-2023 06:01 AM
Hi
ive just had fibre installed with an ONT box on my wall. How do I swap the ee smart hub for my ASUS routers as I’d like to create a mesh network. I read somewhere you connect to WLAN port and login with PPPOE but which login do I use?
thanks
29-06-2023 06:07 AM
No, You connect the ONT to the WAN port of the router by Ethernet.
In Home Broadband settings you'll find everything you need to set up your own router.
29-06-2023 06:07 AM
29-06-2023 06:14 AM
Thanks. When reading that link it seems to say that the username and password is set when the ee smarthub is installed and after parental controls are set. I didn’t have any of that though , I just opened the smarthub box and plugged it in and it worked .
29-06-2023 06:20 AM
The BB Username & pwd are auto set when an EE router is 1st used. Nowt to do with any parental controls.
29-06-2023 06:29 AM
Thanks but where can I find the username and password if they’re auto set? If I plug in the ASU’s router will this auto setup username and password as well?
thanks
29-06-2023 06:43 AM
It only auto sets an EE router. So you plug in the EE router 1st & look for the BB Username it has set. Then unless you are a v. old EE user you can work out the pwd from the link I gave.
