Stop devices connecting to EE 7 Wi Fi Pro
RCripps
I have the new EE 7 system with 1.6 Ghz FTTP.
i have two Wi Fi Pro units. One is used to extend range and is over the other side of the house.  However the other one is just above the main router.  The router is downstairs, I have a CCTV system upstairs above it and need the Ethernet port.  Having the main hub and the Pro so close is causing issues just as it says it may.  Is the way of stopping devices connecting to the Pro so I am effectively just using it to connect an Ethernet port upstairs to my router.
Drilling a hole to feed an Ethernet cable through the floor is messy and the only 3rd party products I can find are extenders as well that cannot be switched off so they will make the issue worse!
Any suggestions welcome!
0 REPLIES 0
