Still no broadband
Pac82
Lost broadband on Thursday 25th June,  had to wait until Monday 29th June for an engineer who diagnosed a dead router ,and who rang EE himself for a replacement. As I had heard nothing by Tuesday afternoon I called to double check ,and was told arriving Thursday 1st July.
Thursday evening I called again as had nothing delivered and also no tracking info to be told it hadn't even been dispatched and a supervisor would "manually order" the replacement. So aside from a complaint resolution email still not connected 8 days later.
came 10 mins ago royal mail tracked 24. Complete surprise as I had no info.
Still sorted now
Maestro
Maestro
@Pac82 Until EE send you a replacement Hub not much you can do about it at all!
Its the fact that the engineer and nown2 different "help" reps have all told different stories is winding me up the most. How hard is it to put a box in the post .
@Pac82 It will be down to the fact Engineer did it and not you direct, you also seem to be aware that no e-mail/no delivery details etc etc. Can also be stock issues getting a second hand replacement unit out the door to you. EE delivery is a tracked item either from RM 48hr or DPD. The it's in the mail just does not work!  Just checked mine was RM 48Hr, sure it was reflected in the account for tracking etc.
Still sorted now
@Pac82 There you go, EE stepped up and sent!
