Speeds
James_OOEligilu
Test Date: 25 Jul 2022 20:20
Download: 36.4 Mbps
Upload: 42.5 Mbps
Ping: 88 ms
Connection Type: Wi-Fi
Server: London
External IP: 95.145.197.124
Internal IP: 192.168.0.117
Latitude: 51.4694060666691
Longitude: 0.117510671597294
@James_OOEligilu : Which router you using? It's not a current EE BB router, more like an old Netgear.
James_OOEligilu
Thanks Grand Master for reply.
I am having to use another modem switched to a plain router to bounce signal around house as the engineer installed to EE modem above the microwave in the kitchen and I think this may be the issue!
