21-10-2026 10:32 AM
I have 4 mobiles with the EE app. After the recent maintenance, two new phones show the speed test and two older ones, one android and one iPhone, now say it is not available.
I cleared the cache and data but still the same.
21-10-2026 01:44 PM
@jak26 EE App is fine when it plays well, fast.com does a little like it but the ONT is were the profile outwards is the Hub has nothing to do with the speed, internal i push 2.2Gb/s combined over the network as a single speed when i kick everyone else off it, but at the end off the day it's a FF500 Internet pipe, but i know it does it when i need the speed.
21-10-2026 01:47 PM
@Maxell Testing just far too hard and way to many variables, EE app as they say whatever works is what you get at the time.
Been a little Android 17 issues going on so wither it is the EE app or the EE account rejecting who knows?
21-10-2026 02:13 PM
I can understand there are a lot of variables but I have 4 phones and can see something isn't right. It is like a lottery each time you log into the app, what will be working. They say Android 8.0 and up maybe start cutting this down. I do use another service provider app and while this occasionally has errors it is quickly resolved.
21-10-2026 02:16 PM
@shakey19811 Correct, link speed on the ONT Nic interface will be that of either device, Hub/ONT if both 2.5Gb/s then that will be the sync reported, either or lower then 1Gb/s will be the next, and 100Mb/s when an oops cable/network or bad negotiation and that happens sometimes.
21-10-2026 02:19 PM
@Maxell EE or there App software company does fix but there is just no timescale to that. Always fun watching it, seen it many times before.
21-10-2026 02:55 PM
But how do they get to know about issues? Many probably don't even use the app, it scores 3.1 on Google Play. There should be an online database to report issues. I have no way of knowing if my issues are widespread or localised to me unless I see a number of reports here.
21-10-2026 03:03 PM
@Maxell There is also the part Account\EE App and Website as well, and google has the report issues developers site, and the app has ""If you do have any questions or need help, please go to: https://community.ee.co.uk/
Does EE CS take note if you call them with app issues?
21-10-2026 05:04 PM
Because of so many glitches in the app, I would not contact them each time, but when I do, they say wait for the app update.
I have just noticed that an update for the EE app is available which is quicker than normal.
21-10-2026 05:39 PM - edited 21-10-2026 05:43 PM
@Maxell Looks like it will also find the other from a few days ago and link below it. Google app store UK.
21-10-2026 06:44 PM
Why are they the same date?
