Speed test broken
Maxell
I have 4 mobiles with the EE app. After the recent maintenance, two new phones show the speed test and two older ones, one android and one iPhone, now say it is not available.
I cleared the cache and data but still the same.
20 REPLIES 20
Maestro
Maestro
@Maxell If you are not 100% concerned with the speed to the hub/device, then there are other speed test's that work just as well but you do need to build a history. Seen it many times were the EE app did not play especially with the speed test part off the app. The one that @shakey19811 has linked good, but setup an account for logon so you can get a web history stored.
shakey19811
Skilled Contributor
Skilled Contributor
just use this instead (web browser via pc)
androd (may opem google play store on your phone
ios
@shakey19811 There is a windows app as well but currently does not link to the web version for history like the mobile version.
jak26
Obviously there are other phone speed test options but can confirm problems with the speed test in  the app. It does have value as it measures speed to the router - does its use not get recommended here when users have speed issues?
Recently the to-device test was giving an error about needing to connect to WiFi (nonsense) but still ran the to-router test - but now it does indeed give the error posted above. There has just been an app update. It's unlikely that something is 'being fixed' .
@jak26 Hard one to say never tried or tested fully, not 100% sure the speed test to the hub is pushing data or not with the speedtest.net you can confirm data push and stress on the connection.
Added when cleared for viewing.
Typical speedtest from the Windows app versionTypical speedtest from the Windows app versionData push from ookla windows app version.
[Second Image Rejected - Image contains PII (full name)]
jak26
I'm surprised the to-router speed test is being under-valued. It is likely 'pushing data' (rather than guessing) as the result number matches what I see at a PC test connected via 2.5Gb/s LAN. The to-phone test gives a very slightly lower result than the speedtest app on the phone does but it's close enough for users to confirm a good WIFI connection - I'm Asus AP on 6GHz to a WIFI 7 capable Pixel giving 900+ results.
Any user reporting speed issues ought be advised -
first to use the to-router test to eliminate external issues or wrong cable ONT to router
and then to study cable choice and ethernet sync speed if its a wired connection router to  PC showing a poor result
or WIFI sync speed and confirm 5GHz use if they're seeing a low to-phone result. 900+ is less likely on 5GHz but 500-800 is possible close to the router.
Maxell
My intention is to highlight bugs in the app. Two nights, the app stated down for maintenance, and afterwards, the speed test on two phones was down. They have I assume fixed ssome things,  and seemingly broken others. Also the Wifi Optimiser is broken on  two phones which  have the speed test showing. Don't  EE test compatibility before releasing new apps, firmware  or doing maintenance?
shakey19811
Skilled Contributor
Skilled Contributor
try cable to a pc if possible not downstream speed if you on ont my understandng is router will in only show ont link speed ?
Redo rejected pic.
Data throughput on windows speedtest app from ookla.Data throughput on windows speedtest app from ookla.
