20-11-2025 06:52 AM
Anyone know what best to do? Tried off and on
20-11-2025 07:32 AM - edited 20-11-2025 07:33 AM
@Hohumhohun : You haven't said which router. There's no Yellow on those I've looked at. Could you mean Orange? That means either your cable is not properly connected or BB is down. If the latter ...
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area.
Have you reported your problem with your BB to EE? They can't do anything about it until you do. Text HELP to 66033 to get EE to test the line & see what needs doing.
What is the name of the EE BB plan are you on including its speed? Which EE router & WiFi extenders, if any, do you have (read label or post a pix)?
20-11-2025 10:13 AM
