Smart Wifi+ technical specs
blackops786187
Im trying to find information regarding the specs of the smart wifi plus device ie attennas for 2.4ghz and 5ghz, max theoretical speeds etc.
Also upon purchasing these devices and then using them with an ethenet backhaul, what SSID do they display? Is it seperate from the main EE smart hub?
Mustrum
@blackops786187   have you seen the help page for Smart WiFi>
Does it answer your questions?
https://ee.co.uk/broadband/smart-wifi
blackops786187
ive had a look at that page and there is no technical breakdown of the specifications
@blackops786187 Do not think that a spec has ever been published, mesh setup and same wi-fi ssid, not sure if you can get to any management screen, and link to user posting.
Smart Wifi Plus Extender doesn't have a Gigabit Ethernet port? - The EE Community
