Smart Wifi Pro - Pairing on 6GHz Woes
Greg_T
Hi there,
So just over a week ago I received my new Smart Hub Pro and 2 Smart WiFi Pro extenders.
I am following the process in the app, but the second WiFi Pro simply doesn’t want to extend wireless! It goes through the setup, from flashing orange / pair / flashing then solid aqua light, but under Connection Type it resolutely says N/A.
I can set it up with an Ethernet connection but I’d rather it was on WiFi!
Any help appreciated!
Maestro
Maestro
@Greg_T Do the wired setup, leave it sitting 24hrs side by side, so it can do an FW updates and that normally sorts them out as a pair!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
And where the Pro and the smart wireless units are heading to for FW.
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3. 17/09/2025 Now https://
If you wish to do it all app wise then good luck to you, may be worth taking a look via the web manager interface instead!
