Smart WiFi Pro extender
Maplebank
Only recently moved from BT to EE and because of the full fibre install, my main hub has changed location and now the majority of the connections are now on the Smart WiFi Pro extender.
I can see by connecting to the hub that there are 19 connections to the extender, but I can't tell whether they're on 2.4GHz or 5GHz?
Is there any way to identify the channels the extender is using?
bobpullen
Star Contributor
Star Contributor
Access the Hub Manager and navigate to Advanced > Wireless > Extenders tab. There's a second topology view where you can see which band of the extender devices are connected to.
Maplebank
Perfect!
Thank you for your quick reply 😊
