Smart Hybrid Connect -flashing red lights
MarshfieldSurf
Set up our new EE wi-fi before Christmas and all works fine apart from this device. The 4g signal bars constantly flash red which can't be good but it's not one of the options covered in the instruction leaflet.  Solid red means the unit is not working supposedly, so does this mean the same thing?
13 REPLIES 13
Mustrum
@MarshfieldSurf    according to the Help page it means
Flashing red
Your device cannot connect to your hub. Try connecting with an Ethernet cable or moving it closer.
https://ee.co.uk/help/broadband/getting-started/hybrid-connect-set-up#article-heading-5
Let us know how you get on.
Thanks, but I think you are talking about the central light, not the 4g signal bars. The device is connected to the hub OK and the central light is glowing solid aqua.  However the signal bars below are flashing red.....
@MarshfieldSurf   sorry, I see what you mean noq. Do you have good mobile signal where you are? And does the device have a sim card and if so has it been activated?
Otherwise if you give the Broadband Care Team a call they should be able to help.
Thanks. Have tried checking for a SIM card and can't seem to access the slot. Assumed it would have come already inserted? Will try that again later, thanks.
@MarshfieldSurf Link to the latest help detail.
https://ee.co.uk/help/broadband/fix-problem/fix-smart-hybrid-connect-broadband-problems
4G signal bars
  • Flashing aqua or blue - Your device is connecting to the mobile network.
  • Full aqua or blue - Your device has a strong signal. 2 or 3 bars are good.
  • 1 aqua or blue bar - 1 bar is okay, but you may be able to improve your signal. Try using the EE app to help you.
  • Full white - Your device is using mobile data to support your broadband. 2 or 3 bars are good.
  • One white bar - 1 bar is okay, but you may be able to improve your signal. Try using the EE app to help you.
  • Flashing red - Your device cannot connect to your hub.
    Try connecting the device and hub by ethernet cable or move the device closer to the hub.
  • Full red - There's a problem with your device. We'd like to help, so get in touch.
bobpullen
Star Contributor
Star Contributor
In my experience, the signal bars shouldn't flash red whether the unit is paired to the hub or not. They should independently reflect the state of the SIM provision.
@MarshfieldSurf - you should be able to access the SIM tray on the underside of the device. You'll need to stick something in the pinhole to one side to release it. Might be worth taking it out, cleaning it and re-inserting it to see if it helps. Failing that, my money would be on a SIM provisioning issue that would require interation with the Helpdesk to sort.
Thanks. Have now managed to get into the SIM tray. Sim card present and correct so I agree, this is probably a job for customer services.... Wish me luck!
Interesting, I can't understand why the flashing red signal bars would be about not connecting to the hub when the central light says it is connected to the hub. Plus I have connected with an ethernet cable to be doubly sure.....
@MarshfieldSurf Luck wished, and you may well need it, the documents and help on the Hybrid are just a little bit out there explanation wise for LED status etc...
