Smart Hub Pro, No UPNP Ports Forwarded for UPNP Enabled Devices in Firewall Li
aviator56
I've just had the latest S H Pro installed, replacing my BT Home Hub 2.
None of the UpNp enabled devices that should set up port forwarding upon connection to the hub are showing in the Firewall Table.
I can set up port forwarding manually in the Firewall table, but none of the devices connected to the network that happily set up port forwarding on my old BT Home Hub 2 appear in the irewall list
UpNp is set to "on" in the advanced settings and I've toggled that on and off, and rebooted all of the devices that should set up ports under UpNp several times.
Any idea how or fix this fundamental issue please?
Maestro
Maestro
@aviator56 If it is working with the BT Smarthub2 then put it back on the network, and forget about trying the new router.
Is there a BT Home Hub 2 router, cannot find a ref on BT Site?
Ewan15
Expert Contributor
Expert Contributor
@aviator56  I would suggest you get the port forwarding settings from you BT Router web interface and replicate them on the SH Pro.
There is a bug with the SH Pro though when setting up port forwarding it sets the affected devices to static.
You would then need to change the IP address(es) to move them out of the DHCP zone, however the router web interface will not allow you to do this.
Thanks for your reply, I've probably misquoted the BT hub name, it was the last ADSL model they supplied.
The new router is the WiFi-7 standard and much faster than the old BT one, although I have retained it for the time being, it would be a retrograde step use it!
Thanks for your response, I did copy off all the port forwarding details from the old BT hub and have mannually entered them into the SH Pro - though not all seem to be working, particularly with some security cameras.
So far EE support havent come up with an answer, though I find it hard to believe I am the only user for which UpNp port forwarding isn't working
@aviator56 Can count on one hand how many complain about it, so your assumption may have some foundation, there are some post's on forwarding with the Pro router, suggest search and read, also like yourself some modifications were required to be done to get things working.
