24-02-2026 10:15 PM
We just moved over to EE Broadband after many trouble free years with Plusnet - because we wanted to keep a landline, which Plusnet apparently will not support in future.
Trouble is, now we're with the EE router, our Sky Stream box loses the Internet connection on a daily basis. It's only the Sky Stream - every other device (mobiles, iPads, home computer, laptop, Eufy security) are fine. We're having to reboot the router every single day, and it's incredibly annoying now. I've tried turning off the 5GHz frequency band, also tried using an ethernet connection to our Sky Stream box, both to no avail. Apparently it's the connection of the router to broadband service that's the problem.
Searching online this appears to come up as a question time and time again, it's clearly a known problem. Are EE doing anything about this? Or are there any recommendations that might work to resolve this? I can't swap to a 'non-EE' router as the landline requires the EE router to be the primary broadband connection.
Many Thanks
25-02-2026 07:36 PM
@Runikfam Be sure to see that the compatible wifi is sitting on WPA2-PSK, waste as your device is a AX mode wifi connection but the stupid hub will be the issue!
25-02-2026 08:18 PM
Just turned on Compatible WiFi, on WPA2-Personal. The Sky Stream puck is connected for now (although I rebooted the router, which normally worked for a while anyway...).
05-03-2026 09:41 PM
I am seeing this exact same problem after some recent BB changes from EE and I am very interested in progress on this topic.
05-03-2026 10:32 PM
@bethankit16 Ethernet connect the device.
08-03-2026 03:00 PM
Unfortunately it's not fixed. I've tried an ethernet connection, I've tried turning off the 5Ghz frequency, and now tried using 'compatible WiFi' but we still get almost daily 'It looks like you're not connected to the internet' messages. The messages are saying that the Sky Stream box is connected to the router, but it's the router that is not connected to the internet. No idea what to try now, other than continuing to reset the router daily.
Strangely, we can usually still get our Sky streaming channels to work (even with the no internet message) by pressing the 'Home' button on the remote control multiple times - but can't get the Apps to work (YouTube, ITVX and so on).
08-03-2026 04:57 PM
@Runikfam describes the exact same symptoms I am seeing including the functioning streaming channels via the Home button but no apps. Ethernet connection is no better.
