Signal - lack of
Mikebike123
My fibre optic broadband has a terrible signal. Keeps going down regularly. I use it for a mobile, p.c., and t.v. my TV is currently running under 2 mbs. When I complained months ago, apparently there was a fault in the line somewhere outside. When they rectified this, I had 30mbs. I was ecstatic. Absolutely amazing. Never had that before. Lasted 2 days. Been operating on average 2mbs. I'm at my wits end. It's rubbish.
