Should I disable EE Router WIFI?
JR1208
I just installed the BT Whole Home Mesh Wifi.  Should I disable the wifi on the EE router?
It's up to you. I find it useful to have separate SSIDs for each router. That way you know which 1 is connecting to which device and can switch them around if appropriate.
