Router plugged in, connection in 3 days, can I use EE wifi hotspot until then?
igc3245
New customer, relying on mobile data (not EE, Lebara) until broadband is connected on Tuesday. I have a new EE broadband account, but until the BB is switched on, am I technically a customer with access to the hotspot?   It looks like I can use EE WiFi hotspot for free until I'm properly connected. I've logged in to the EE Mobile hotspot. Is this right? Thanks.
Maestro
Maestro
@igc3245 As long as your account is active and your ID/Password works you can give it a go and see, if it does not work then try it once your Broadband is live and connected that way!
Maestro
Maestro
