Reduce EMF's from EE Smart Hub Plus
asrehman
Can you please tell me how I can reduce the EMF's strength on EE smart Hub Plus. I have changed it to 2.4GH only. and to wifi 5.
Should I also change the channel to 1?
What else can I do
6 REPLIES 6
Mustrum
@asrehman  not sure your actions will make much difference.
The following Gov Help page may help provide further guidance.#https://www.gov.uk/government/publications/electric-and-magnetic-fields-reducing-exposure/electric-a...
asrehman
I have the EE smart hub plus grey router,
How can set the Transmit Power to 50% or 25%. As the signal is too strong and making me ill.
Mustrum
@asrehman  there are no adjustments to any power settings.
RG999
If this is making you ill, make sure you keep away from any mobile phone. The transmissions are many times stronger.
@asrehman If you do not require any wireless comms and are using everything on ethernet wired connection, then you can turn of both the 2.4ghz and 5ghz signals on the router from the web admin.
@asrehman  your safe to use both frequency.   If you’re concerned about EMF then you shouldn’t use any other electrical equipment as all electric devices gives off EMF.      You might want to read THIS
