Re: unable to connect
Michael4658
Unable to connect Battey security camera throw my WIFI keep getting not found use to be able to connect when on sky
XTU Wireless Video Doorbell Camera with Chime, 10 unable to find the router.
Michael
7 REPLIES 7
@Michael4658  If your doing this via the app for the doorbell you need to make sure your device is also connected 2.4Ghz WiFi from the router.   It would be beneficial if you switched off the 5Ghz connection on the router.
@Michael4658 : What is the name of the EE BB plan are you on including its speed? What EE router & WiFi extenders do you have (read label or post a pix)?
Michael4658
Hi i have switch off the 5g of the router and on my phone and it will still
not find a connection and it will not connect to STRN
Kind Regards
Michael Stanley
Michael4658
Essentials: Full Fibre 150
100 Mbps
And no WIFI filters
100 Mbps
Kind Regards
Michael Stanley
Peter_W
Hey there @Michael4658, thanks for giving that a try with disabling the  5Ghz connection.
If possible can you please try switching the security from WPA3 to WPA2 and see if this makes any difference.
It's worth checking to see if the doorbell has memories of your old network at all too, as if this is the SSID they're trying to connect with by default it could be restricting it finding new ones.
Peter
Michael4658
unable to to change WPA3 to WPA2 as not sure bets way to change it.
Michael
Peter_W
Thanks for having a check of that for us, @Michael4658.
If you're not seeing the option to switch this, then an alternative could be to look at enabling Compatible WiFi.
This creates a separate network that works better with certain kinds of devices, so fingers crossed this is something your Doorbell will find this easier to connect with.
Peter
