Re: Live chat with EE
Hanah88
There seems to be a problem with my broadband. I've text and they are saying they cannot find an account
6 REPLIES 6
James_B
EE Community Manager
Hi @Hanah88,
What problems are you experiencing with your broadband?
It's very slow and keeps disconnecting WiFi off my phone
James_B
Hi @Hanah88,
Are you able to provide the information requested in Need Help with Your Home Broadband Speed or Connection? so the community can help?
@Hanah88 : Welcome to EE's Home Broadband Forum.
The light on the router is staying the bluey colour but the WiFi is going down. It's very slow and app like netflix and BBC I player are buffering
Leanne_T
Hi @Hanah88
If you give us a call on 150 or 0330 123 1105 the team will get this looked into for you 🙂
