Re: Frequent disconnects
dacr17
I am experiencing the same issue. Broadband constantly drops, and no, it's not wifi, but the entire router, here's a sample of a message I get digging up the router log:
WAN connection WAN2_INTERNET_PTM disconnected. [ERROR_NO_CARRIER]
I have had 2 OpenReach engineers over to confirm line is fine. EE has sent me a new SmartHub, but to no avail. I am very **bleep**ed with this, as both I and my partner work from home, and have constant Teams meetings. Unfortunately I've just signed another contract extension, so I feel stuck with this ridiculous service..
15 REPLIES 15
No, I don't have one, and I've just been explained by EE support that as I don't have a voice line, connecting to the test socket directly won't work.
In which case I'll leave it to you. I don't see the point of coming here when you are going to rely entirely on what OR told you. What more do you expect us to be able to tell you?
Mustrum
@dacr17   that is a shame, but the info you got from support is rubbish.
The dangly filter converts a phone type socket to a RJ11 interface, and filters out the higher frequencies to the phone connection. The test socket still carries the VDSL frequencies, it just needs a physical conversion, that the dangly filter supplies to work.
Frankly, I would have hoped you had some knowledge about this type of error: WAN connection WAN2_INTERNET_PTM disconnected. [ERROR_NO_CARRIER]
And surely you can see that this is no wifi issue.
Yes, all it means is that the BB went down but you know that already as you experienced it.
Yes, I already see that it is not a WiFi issue. Hence the need to investigate noise on the line at the test socket. Noise on the line is the most common cause of BB failing or going slow.
Ok, thanks. I'll try to find one of those dangly filters and run the test.
