Re: Frequent disconnects
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 02:36 PM
I am experiencing the same issue. Broadband constantly drops, and no, it's not wifi, but the entire router, here's a sample of a message I get digging up the router log:
WAN connection WAN2_INTERNET_PTM disconnected. [ERROR_NO_CARRIER]
I have had 2 OpenReach engineers over to confirm line is fine. EE has sent me a new SmartHub, but to no avail. I am very **bleep**ed with this, as both I and my partner work from home, and have constant Teams meetings. Unfortunately I've just signed another contract extension, so I feel stuck with this ridiculous service..
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 02:44 PM
@dacr17 : Welcome to EE's Home Broadband Forum.
- For a BrightBox: login and go to Advanced Settings > System > DSL Status. Also post 'System Uptime' from top of System Log page.
- For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
- For other routers: login to it according to the label on it as the admin user & navigate looking for its router/connection statistics.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 02:46 PM
@dacr17 even if you had not just signed a new contract, if you still have a fault on your line it needs to be fixed. Unfortunately faults are not always able to be identified straight away, sometimes complex faults can take time to identify and fix.
If you post the information requested above we maybe able to help to get the line fixed.
HTH
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:02 PM - edited 10-03-2023 03:07 PM
Here's the information you'd requested:
Product name | EE Smart Hub |
Serial number | +EEH001+2050003114 |
Firmware version | v0.08.02.12273-EE (Tue Dec 27 16:07:25 2022) |
Board version | 1 |
Data sent / received | 263.2 MB / 99.0 MB |
DSL uptime | 0 days 0 Hours 24 Mins 55 Secs |
Data rate | 18.02 Mbps/80.00 Mbps |
Maximum Data rate | 18.0 Mbps/80.8 Mbps |
Noise margin (up/down) | 6.0/4.1 |
Line attenuation (up/down) | 23.8/18.7 |
Signal attenuation (up/down) | 23.7/18.7 |
Broadband username |
2.4 GHz wireless network name |
2.4 GHz wireless channel | Smart (Channel 6) |
5 GHz wireless network name |
5 GHz wireless channel | Smart (Channel 48) |
Wireless Security | WPA |
Wireless mode | Mode 1 |
Firewall | Default |
MAC address | 60:8D:26:89:D3:83 |
Software variant | - |
Boot loader | 0.0.3-EE (Mon Dec 4 17:32:53 2017) |
I've purposefully removed the network name information. As you can see, the last time I've had a dropout was 24 mins ago.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:05 PM
Thanks but remove your BB Username.
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Try the BT Quiet Line Test (QLT), dial 17070 Opt 2, preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report it to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Reboot the router & plug it into the test socket. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:09 PM
I have to say, you have the same response to everyone, which makes me wonder whether you're a human or a bot. I'm inclining to believe the latter, as you seem to have totally ignored the fact that I had 2 OpenReach engineers come over and run a bunch of tests (one even replaced the entire OpenReach box), so I don't see any point in doing your tests.
Is there anything else you can suggest?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:11 PM
thanks @dacr17 I guess the good news is that you are quite close to the cabinet and have close to the max speeds, and that DLM has not yet reduced your speeds due to the drops.
Was there anything that happened 24 mins agao that could have caused the drop? Even walking past the socket could cause a problem, but testing from the hiddent test socket should identify that.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:30 PM - edited 10-03-2023 03:31 PM
I don't seem to be able to get broadband connected when using the test socket. Here's the status information I get from the router:
Board version | 1 |
No, nothing special happened when broadband dropped. Me and my partner are both sitting at our desks when it happens.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:38 PM
Board version | 1 |
I can't seem to connect using the test socket. Not sure why.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
10-03-2023 03:41 PM
@dacr17 are you using one of the dangly filters that come with the router when trying to connect in the test socket?
- DSL Reset. in Broadband & Landline
- Waking PS5 from rest mode, not staying connected to internet. in Broadband & Landline
- Devices disconnecting every 5 minutes in Broadband & Landline
- WiFi 7 extender keeps disconnecting from my ethernet connection in Broadband & Landline
- WiFi 7 Hub Extenders random disconnects in Broadband & Landline
