11-04-2024 02:44 PM
I concur that the EE hub is VERY naïve!
I cite the following functionality examples:
* Firewall by default is ON , there is seemingly no option to turn it OFF - even momentarily - to test issues ?
* Wifi channels on 2.4 GHz can only be set to "Smart" 1,6, or 11 - we live in the UK with European channels! not the USA for Dawkins sake! We have channels 1 to 13 which allow for 4 channel frequency planning (1/5/9/13) can I set channel 5 ? (verified with a spectrum analyser as my cleanest channel) no! - this is STUPID in the extreme!
* Either there is some upstream NATing going on or the DMZ IP function doesnt work properly for UDP traffic (see my separate post for details)
EE suggested I "provide my own PPPoE fibre router" well it seems I cannot do that as I dont have the PPPOE credentials!
They are sending someone out on Monday (I am not confident of resolution) but beyond frustrated right now
regards
BB
11-04-2024 06:24 PM
PPPOE username and password is [email protected] and password BT with CHAP as authentication.
