06-01-2023 09:40 AM
I have just changed from EE to BT Broadband. We currently have the EE smart hub and been issued the BT Smarthub 2, which I am assuming are effectively the same hubs
The change over is due today but the Internet still works though the EE router. Will I still be able just to continue to use the EE router instead of swapping onto the BT router to save the hassle of connecting all devices to the new hub or will I benefit from the new hub at all?
06-01-2023 10:36 AM - edited 06-01-2023 10:37 AM
@Gordon460 : Depends on which BT BB product you've switched to. Which is what?
The EE & BT routers you mention are not the same:
What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
06-01-2023 04:53 PM
A quick correction:
The black EE Smart Hub is based on the BT Smart Route, often referred to as the BT Home Hub 6.
06-01-2023 04:59 PM
Sorry, I meant BT HH6 but it must be Type B with Port 4 the red labelled WAN port & not the original Type A without WAN port.
06-01-2023 05:06 PM
It is the white EE route I currently have and I have now been supplied the black BT smart router 2.
Will it cause any issues if I do not change the routers over? I don't see the point if they are effectively the same
06-01-2023 05:18 PM
It might! They are equivalent but the BB creds will be different. You will need to consult the BT wallahs whether BT BB accepts/ignores EE creds or you will need to change them to the standard user-independent BT creds.
C.f. EE BB does accept the BT creds.
06-01-2023 05:39 PM
@Gordon460 there are a couple of things which you may wish to consider.
As already mentioned, BT and EE use different Broadband Usernames and passwords, I suspect your EE one will not work for long on the BT network with your EE details. Once you account closes, it should be deleted but I have no idea how long that will be. You could change the EE Router username to bthomehub@btbroadband.com password may or may not be bt, and see if it works.
Alternatively, on the BT Hub, change the SSID (Wireless name and password to be the same as your EE Hub, then you won't have to change your devices. Just remember to put them back if you ever factory reset the Hub..
One advantage of the BT Hub is it's ability to add the Wireless Mesh Discs if you have issues with Wireless around the house. Aparently the new BT ones only work with a BT Smart Router.
06-01-2023 05:49 PM
It is irrelevant whether or when users' EE BB creds are deleted from EE's Authentication Servers. BT BB will never consult them. The only Q remains as to whether BT BB will ignore the EE creds in the router much like EE BB accepts BT creds.
17-03-2023 03:16 PM
You haven't answered my question which is that I have just moved to EE from BT and still using a BT hub, does it need changing to an EE hub?
17-03-2023 03:31 PM
Hi @margaretenglish,
I'd recommend using your new EE hub.
