Re: Are my speeds being capped or reduced for some reason?
Bahnan
I am from Talk talk broadband and used to get crazy fast speed of 160Mbps for the same price, now reason I moved from talk talk was intermittent connection issue, my new Essential: Fibre 67  is up and running and working but supposed get 66-76Mbps instead I am only getting 20 Mbps. this is huge difference on what promised!
any reason why 20Mbps?
