Purchase an extra Smart WiFi Pro
RobBark82
I’ve just ordered the 1.6gbps broadband with WiFi 7. I currently run an EERO Pro 6e system with main hub and two additional units. Is it possible to order an additional Smart WiFi Pro so I can have three units like I have now?
You're entitled to 1 more if 2 isn't sufficient. See Smart Hub Pro and Smart WiFi Pro speed guarantee
Brilliant, thank you.
Maestro
Maestro
@RobBark82 One hub Pro and up to 3 smart wireless Pro extenders as required, you may need to get the Engineer visit, but you will find that out when you contact EE to get your 2nd one.
