18-06-2025 01:03 PM - last edited on 18-06-2025 01:56 PM by Christopher_G
I understand your concerns. My experience with the transition from BT to EE has been similarly disappointing. And now i am with them until like 2k26
18-06-2025 01:10 PM
18-06-2025 01:36 PM
Speeds that was promised not being met ie 52 is minimum but getting between 12-32
18-06-2025 01:37 PM
I having my 2nd engineer out on Monday fingers crossed some improvements but I will not hold my breath
18-06-2025 01:44 PM
@Daz_01 : Welcome to EE's Home Broadband Forum.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
18-06-2025 03:23 PM
I've done a formal complaint just had someone from ee guild calling ring me about it so waiting for engineer on Monday and ee are calling me on the Tuesday to see how things are i will keep everyone posted
24-06-2025 10:11 PM
As it stands the 2nd engineer came in and found a fault outside my house and said he has reported and opensure will fix it. But according to the man who rang me said no report has been made so he and I are not happy with that outcome. He has made a appointment for opensure to come on Thursday not in 2 weeks like the engineer said fingers crossed it's sorted soon
