Port Forwarding Issue
IIIIIIIIIIIIIII
Apologies for the long post however I've tried to give as much detail as possible.
My daughter has a Minecraft server which has been setup for years using port forwarding for the server and also for voice chat. We moved from BT to EE and set the relevant forwarding up for the server and the voice chat however whilst the server has no issues we're unable to get the voice chat to work.
We have tried changing the port however no matter what we select our testing returns that the port must be closed. This is despite everything on the router looking as it should. Whilst I'm fine setting up the forwarding etc I don't know as much as my daughter therefore I've had her send me (see below text) info regarding what she's done and how she has determined that it's the router/port that's the issue:
Hello I am currently having difficulty forwarding a port. I run a Minecraft server which is accessible to people outside my network on an ubuntu machine, however, recently I have been trying to get simple voice chat working which requires another separate open port. I tried to open the needed port from my router but it is still not open.
You may wonder how I know it is the port and not something I am doing. To determine this I went onto my ubuntu machine and did a tcpdump for the port I knew was open, and then used my phone on 4g to send udp packets to the public IP. This worked fine and I could see the packets coming in. I then tried the same with the port I didn't know if was open and I could not receive any packets.
I also did another test where instead of connecting to my minecraft server from the public ip with ddns, I connected with the private ip, when I did this voice chat was working. As well as obviously I could see packets through tcpdump. It's just external users that can't use voice chat. I'm not really sure what to do now since I've added the rule on my router but it's clearly not open.
In addition we have also tried following the relevant steps of turning off upnp and adding the port range back in. Have also tried different number ranges rather than the default 24454/udp.
Not sure if this is relevant/helpful. I had also read elsewhere that there's a brief handshake with tcp before routing voice over 24454/udp. As such I tried setting up the port over udp/tcp rather than just udp however when putting the range into internal the external port range turned red. From what I understand this occurs when there's an overlap however there's no other port forwarding with this range (or close to it).
Smart Hub 7 Pro - Version 3.14.5
Any help would be greatly appreciated
28 REPLIES 28
@IIIIIIIIIIIIIII The norm in a good working uPnP hub, is when the device is turned off where you captured that picture posting the device disappears from view and is NO longer functional. but EE may be doing the Grey it out and then who knows what is going on, does that trip it all up, the sure fire way to get it all gone is linked earlier in this post if you read that... Will link it separate, give me a second. Treat the Pro as the Plus currently until future conformation.
Solved: Smart Hub 7 plus - Port Forwarding horror. - The EE Community
Thanks will look at this and see where it takes me.
I have found what all 3 devices are and can turn them all off, if this still helps?
@IIIIIIIIIIIIIII The link is going to take you down the Factory Reset to get it all working if as @XRaySpeX has put disable the uPnP feature on one off the screens, if they stay Greyed out then the only way to rid them from the Hub quickly is a Full Reset but before you do that sit and think what heartache it is going to cause you if any, there is NO backup/recover for the Hub, but the do now say the DV side for landline contacts is working for Backup/restore if you are indeed using a landline.
Other way just stick your BT Equipment all back on the connection, working before good chance it is all still working, especially if it is a BT Smarthub2 version that supports the DV function.
Apologies I missed your response as I was jumping in and out of other pages with similar issues re PF.
Yesterday I deleted the one which wasn't port forwarding, turned off uPnP, rebooted the router, added it back in. Currently it's turned off however are you saying I should delete the 4 greyed out rules?
@IIIIIIIIIIIIIII If you can then yes, go for it and see what happens. You can easily create them again from scratch just do not stick the zero value in, match the first entry to the second.
I was hoping that by disabling uPnP then the router couldn't possibly create any uPnP generated rules. Possibly after a reboot.
Thanks again.
Yeah so the greyed out PF should've vanished (they didn't) as the picture was taken with uPnP turned off. I have read the link a few times now. When researching this yesterday I found those posts however I did read them again when you posted them.
Unfortunately the routers were sent back to BT so I no longer have them.
It'll be a bit of a headache factory resetting however if I have to do it then so be it. Only thing I would ask is that I have a landline also. Is there anything to worry about there?
@XRaySpeX Plug and Pray is the other explanation at the best off times, did think you were going that way though.
@JimM11 : Dunno what you are talking about. What way am I to go? I've already talked about uPnP.
In looking for those 3 devices that were part of the greyed out PF. One of them was a Playstation and the on PF I've ever done for that was for a game my son had issues with. That was when we were with BT and around 10yrs ago! Not sure why it would be showing up on this router.
